Witam rowniez
Wlasnie wczoraj znalazlem w Inecie blog na ten temat (Deploying LabVIEW Code):
http://ideasinwiring.blogspot.com
QUESTION:
1. What if you don’t want to give the person the source code?
You don’t want them to see how you made the application.?
ANSWER:
If you don’t want to give the person the source code, you have two options. The first option is to password protect the VI. The second is to remove the source code of the VI. In versions of LabVIEW before 8, you could do a “save with options” to do this. In LabVIEW 8, you make a source distribution target and use the “Customize VI Settings” button to tell it to remove the block diagram (and/or front panel)
Pozdrowienia
Artur
